iPhone 8 keeps rebooting when charging
I replaced the battery on my IPhone 8 last week, and every time I go to charge it, it restarts and reboots. And idea how to stop this?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Do a thorough visual inspection, preferably with magnification, of the area surrounding the battery connector. There are several tiny SMD components just above the connector. Of particular importance are the ones highlighted in blue below. If any are missing (which can happen when you pry the connector off), then the battery state does not get communicated to the CPU and this can also cause charging issues and fluctuating readings.
Bu yanıt yardımcı oldu mu?
Put it back the old battery then observe if your phone still restart.
i think your new battery has a problem.
my iPhone 8 is running too slow, and it takes around half an hour to open it after placing it to charger I usually charge my iPhone through laptop
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 567
1 Yorum
Are you powering it off before you plug it in? Because all i-devices are made to start back up when plugged into power.
Jessica Parnelli Fawkes tarafından
