Ana içeriğe geç
remove cover with screen protector
Can I remove the phone cover with isclack or suction cup without removing the screen protector glass first?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
short answer , yep just did it
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
if you are carefull enough then it is possible, when you have lift the front put some thin knife in the gape between front and housing at the bottom.
Puan 2
Yorum Ekle
My preferred method would be to use the iSclack to get in-between the frame and the screen just enough to get a pick under the screen. Then use the pick to loosen the clips. Works every time even with screen protectors.
Puan 0
Yorum Ekle
Yanıtını ekle
Patrick sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 110
