Ana içeriğe geç
LTE özellikli bu Android Wear 2.0 saat, doğrudan Google veya AT&T'den satın alınabiliyordu. Teknik özelliklerinde listelenmemiş olsa da aslında Verizon'u desteklemektedir. Model numaraları W280A veya W281A'dır.
lg watch replacement band
is their any way to replace the bands on a lg watch sport even thought the watches bands are packed full of NFC antennas and many more things needed for it to function properly one is broke and im not sure where to get a replacement piece
Bu iyi bir soru mu?
Puan 1
4 Yorum
model is w280A
tarafından
Hi, I think the only way to get it is from here:
https://globaldirectparts.com/oem-lg-wat...
You have to buy both straps separately.
And yes, it's easy to replace them: Just remove the two screws on the sides of the strapholder and gently pull out the straps, by pressing them also slightly towards the backside of the watch. Like this you're able to click out the two bands, which have connectors towards the watch itself.
The new straps can be attached in the same way again... Good luck! (Have to replace mine too, as they have been proken both together now after only 2 years of usage! Crappy design... The next watch is for sure not a LG watch anymore...
tarafından
There is a website that sells the bands for $35 per side but they are on back order.
I found a guy on ebay that sells refurbished ones that he makes with a 3d printer for $70 for both sides shipped.
https://www.ebay.com/itm/LG-Watch-Sports...
tarafından
Then I found another guy that sells replacement bands on ebay without the antennas, so you have to remove the antennas from your origianl band and slide them into the replacement for $21 for both sides shipped.
https://www.ebay.com/itm/Lg-sport-watch-...
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
YES! It’s easy… check out my new guide!!
LG Watch Sport kordon değişimi
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Where can I find replacement watch band for an LG w280
tarafından
Yorum Ekle
En Yararlı Yanıt
Found it! they sell each separately https://globaldirectparts.com/oem-lg-wat...
Puan 2
1 Yorum:
No longer available. These links are old.
tarafından
Yorum Ekle
Puan 1
2 Yorum:
Wow, thanks for all those links! In my watch, the both antennas were broken also, but solution 1 and especially 2 sound good! And to be honest: I changed to the TicWatch pro 4G in the meantime and are really happy with it, especially regarding battery time thanks to the layered double display.
Well, on solution 2 just the protectors are printed with a 3D printer, the band itself is an original one as it looks like. Thanks for sharing!
tarafından
You're welcome. Happy to share, hopefully it could help others in the future.
tarafından
Yorum Ekle
I found my replacement straps on eBay, they really do have almost everything for sale on there.
Puan 0
Yorum Ekle
for you that need a straps repleacment for LG W280 , i can provide it as a custom made by hand with leather based . just add my telegram @itbloon and i will send the pic .thankyou
Puan 0
Yorum Ekle
Yanıtını ekle
Hayden Rogers sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 5,906
