Ana içeriğe geç
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 Soru Tümünü görüntüle
iMac 27 late 2015 CPU upgrade with i7-6700?
I know you can upgrade the late 2015 iMac 27 with the i7-6700K. But I can get a i7-6700 for much cheaper that the i7-6700K.
Has anyone tried it?
Thanks
p.s. I know the iMac is difficult to open. Already did it many times before.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum
Did you find any solution for this? I’m also looking to a 6700.
tarafından
@kim_sv yes, it’s working - tried it today
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If you already went through the very stressful process of opening and disassembling the unit the CPU replacement shouldn't be a problem. I did it myself though I've used the 6700K - can't see why the 6700 wouldn't work after al my unit had the 6600 (not the unlocked K).
One thing though: the spring that holds the heatsink in place can be a very difficult thing to put back and maybe even damage your CPU - ANY CPU if you're not careful enough.
I recommend ‘flatten’ it a bit using a plier or whatever you can. It should still work as to hold the heatsink in place but if it is too strong that you have to push down very hard (and I am quite a strong person…) you should definitely ‘flatten’ it or you WILL damage you CPU. Check the CPU replacement guide and read the comments on step 62 - you'll see I'm not the only one who had a problem with that:
iMac Intel 27" Retina 5K Display CPU Replacement
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Tried it, it’s working and running @3,4ghz
Update (21.09.2021)
see attached picture for proof :)
Puan 1
Yorum Ekle
Yanıtını ekle
mollocampo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 60
Her zaman: 4,131
