Ana içeriğe geç
Scotch model TL901, dokuz inçe kadar genişlikteki düz nesneleri lamine eden bir termal laminasyon makinesidir. İki sıcaklık ayarı içerir ve beş milimetre kalınlığa kadar olan poşetleri lamine eder.
Scotch TL902 laminator assembly instructions
I recently got the scotch laminator tl902..the sheet was jammed so,I opened the machine and removed the jam..But, now unable to assemble it back..Any step by step instructions with pictures would be great help
Bu iyi bir soru mu?
Puan 1
2 Yorum
How can I close the input tray on my laminator tl902 when finished and want to put it away?
tarafından
How do you get the insert tray out in the position needed to insert
laminating sheets?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Here’s a link to the ifixit Scotch TL901 Teardown guide, which may be of some help
You may be able to reverse the procedure to re-assemble the laminator.
Research online indicates that the only differences between the TL 901 and the TL 902 is that the TL 902 is newer, lighter and has a side handle for easier carrying.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
how do you get the back to open to put pouch in... brand new
tarafından
@ann45280
You don't need to open the back.
You place the item to be laminated into the laminating pouch and then feed it through the machine.
Here's a video that shows how to use it.
tarafından
Yorum Ekle
Here's a picture of how the TL902 roller tension spring is assembled.
Resim
Here's a picture of how the back TL902 older model roller gear is assembled.
Resim
Here's a picture of how the back TL902 newer model roller gear is assembled.
Resim
Here's a picture of how the front TL902 roller gear is assembled.
Resim
Here's a picture of where the TL902 bottom screws go.
Resim
Here's a picture of the one TL902 side screw location.
Resim
If you need pictures of anything else on the TL902, just ask. Cheers!
Puan 1
1 Yorum:
I have a part that is from the other side it’s long and has a circle at the bottom can’t remember where it goes
tarafından
Yorum Ekle
Yanıtını ekle
anusharao.p sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 24
Son 30 gün: 103
Her zaman: 4,927
