Ana içeriğe geç
Jensen JTA-230, 2004 yılında piyasaya sürülen 3 hızlı bir stereo plak çalardır.
Turntable not powering ,while connected
Have Purchased Jensen JTA 230, it was working perfectly with an voltage adapter step down 220V (since am using in INDIA ,where power supply is 220V).
It was working properly for 1 year , but suddenly it stopped working . Not able to know the reason , as the adapter is working properly (checked in the local store) but turn table is not working .
Please help here with some input .
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Hopefully no one connected the turntable to the 220VAC power without an adapter which lowers the voltage to 120VAC
You may have to open the turntable and inspect it for any obvious damage, such as burnt out components, blown fuse etc.
Here’s a link to the ifixit Jensen JTA-230 guide which may be of some help in dis-assembling the turntable.
If there is nothing obvious, you may have to start doing static (power totally disconnected from the turntable) point to point testing of the power circuit using an Ohmmeter (function in a DMM - digital multimeter) to find the problem. Start where the power cord connects to the circuit board.
If you do see something and you’re not quite sure, take some close up pictures and post back here and hopefully there will be further help.
Here’s how to do this. Mevcut bir soruya görsel ekleme
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
abhishek sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 645
