Ana içeriğe geç
Cut electrical wire cord for A1243
I need to know how to replace the cable or repair it.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
If it is an USB cable that was cut then you should open your keyboard and re-solder a new cable to the PCB. Please mind to properly connect polarity of the USB power supply and Data cables. It will be 4 wires + ground so if you are handy with soldering iron then you should handle with it.
Bu yanıt yardımcı oldu mu?
Puan 5
Yorum Ekle
then finish your %#*@ teardown and fix it while your doing it
Puan 0
Yorum Ekle
Yanıtını ekle
GR Oliver sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 29
Her zaman: 1,196
