Ana içeriğe geç
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
Is it ok to replace the screen
I dropped my phone and now it has a slight bend. Should I get it fixed?
Bu iyi bir soru mu?
Puan 0
1 Yorum
Why not sure you can fix it .There is small bend no problem.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Since the iPhone logic board inside is firmed to the housing with screws, there might be consistent pressure on it that could lead to troubles sooner or later. Screen too may be working bad and create issues. It would be a good idea before replacing screen to straighten the housing or replace that part too after removing the logic board.
Here’s the guide to help you do the job:
iPhone SE Logic Board Replacement
Bu yanıt yardımcı oldu mu?
Puan 4
3 Yorum:
The bend is only on the volume rocker side And the replacement is Coming in a week. Is it ok to wait or should I fix it as soon a possible?
tarafından
@shaven_gren It shouldn't be a problem, the left half of the housing is mainly occupied by the battery and smaller components. Unless you feel unusual constant heating coming from the phone it won't be a problem to use it as it is for some time.
tarafından
Alright thanks
tarafından
Yorum Ekle
Yanıtını ekle
rossianthony004 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 121
