Ana içeriğe geç
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Soru Tümünü görüntüle
Liquid damage, Now running slow with overactive fan.
Had a water bottle next to my bed and accidentally knocked it over in the middle of the night onto my mac.
The following day I opened it up, my track-pad was over-responsive, wifi didn’t work at the time either. Wifi and trackpad are working again since I let it air out. However, the slow processing speed has not changed.
There was some corrosion noted near the track pad connecter/cable on one side, otherwise there was no other obvious signs.
The fan is over-working also present on start up.
Can anyone point me towards some resources? I am a novice with Mac repairs, however am comfortable replacing my own display for my iphone if this helps with my skill level.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hey Matthew,
Sounds like a Sensor is damaged. This causes the Computer to think its running a lot hotter than it actually is and throttles down the CPU and runs the fans high. You can use a Sensor Checking software to see what sensor it is.
Sensor check software: http://www.tunabellysoftware.com/tgpro/
If it’s the trackpad sensor you will have to deal with prying out the battery carefully for replacement, otherwise its going to be a Motherboard repair, it shouldn’t be too big of a deal for any repair shop offering micro soldering. As long as they know what they are doing :P
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Matthew McClelland sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 43
