Ana içeriğe geç
Only works when plugged into a charger?
So this morning I was shaking my iPod for the shuffle to work. I guess I shook it too hard because it shut off and will only work if plugged into a charger. It works just fine and seems as if nothing is wrong, but once you unplug it it turns right off. It's done this once before, but it fixed right away. Not fixing this time. What would be the best thing to do?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
follow the steps in the battery replacement guide iPod Nano 4th Generation Battery Replacement to get to the battery. you will notice that the battery is attached using solder points. check to see if they are solid or if any other cables are loose during disassembly.
Good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
It is possible but hard to do mine almost caught fire !!!!
tarafından
Yorum Ekle
Yanıtını ekle
wafflesfasher sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,510
