3.7V 1500mAh 583460 Li-ion
Hello, I’d like to change out my super awesome ps3 wireless headset battery as my usage time has dropped from 10 hours or so to 5 hours. The old is 3.7v 570mah LIP1472 battery and perhaps 8 years old with hundreds of charges. The 3.7V 1500mAh 583460 Li-ion is slightly larger than the original (3mm longer (L) and 1 mm thicker (D), while 4 mm narrower (W)) and I can modify the unit for the size difference. I am hoping to get double the “new product” usage rate at maybe 20 hours per charge. Would this battery work in this application?
Bu iyi bir soru mu?
1 Yorum
Paul did you ever get this issue resolved? I watched the only video online but did not see the battery after he removed the circuit board, Any idea where it is? How is your replacement battery working? I see the link no longer has the battery avaiable.
Larry tarafından
