Ana içeriğe geç
Repair guides and support for electric and gas-powered high-pressure sprayers sometimes referred to as power washers.
38 Soru Tümünü görüntüle
No pressure in my karcher2
I put a bin liner loosely over my karcher 2 because it started to rain,then went back to the spraying and forgot to take the bin bag off.
it ran for a while,then made a awful noise,and I was very quick to turn it off.it will turn on but there is no pressure,can you please help
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi John,
Sorry to hear! Have you tried clearing the unit in case air is trapped inside? Here is a guide from Karcher’s website.
To bleed the pump of any air, turn the machine off and disconnect the high pressure hose and trigger gun from your power washer. With only the garden hose connected to the machine, turn on your water source and allow water to run through the pump of the machine for 20 or 30 seconds. Turn off the water and connect the high pressure hose and trigger gun and try using the machine again.
http://www.karcher-help.com/index.php?/K...
Have a look through the above link as well.
I hope this helps in some way.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Thank you mark,but I’ve already tried that option
tarafından
Yorum Ekle
Yanıtını ekle
John Richards sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 264
