Ana içeriğe geç
The Asus Vivobook Max X541SA-PD0703X is a portable personal computer maufactured in May2017 by ASUS.
ASUS X541S Clear CMOS
On the motherboard of ASUS X541SA, I do not see the battery. Therefore, I can not reset the CMOS settings
Bu iyi bir soru mu?
Puan 5
1 Yorum
Alex AWE CMOS batteries are pretty much a thing of the past. For the last 5-10 years the CMOS information can no longer be reset by that method.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Alex
Try this method, turn on the computer and access BIOS
Please visit this link below.
https://pastebin.com/raw/L3c3rySj
Subtract current year and get the password
e.g.
2019 - 10 = 2009
2018 - 10 = 2008
2017 - 10 = 2007
.. etc
For example:
  • At the password prompt, press alt+r
  • Take note of the date displayed. For me it was 2017-05-11
  • Use Ctrl+F to search the paste bin for your month and date. I used "-05-11"
  • Use the codes you find until one of them works. Mine was the same code as 2007-05-11 from the paste bin.
  • It looks like the codes might repeat every 10 years. So I would suggest starting with the month and date combination from 10 years prior to whatever date is displayed after you press alt+r.
Bu yanıt yardımcı oldu mu?
Puan 4
5 Yorum:
This page is no longer available. It has either expired, been removed by its creator, or removed by one of the Pastebin staff.
tarafından
tarafından
I have the same problem, could you find a solution?
tarafından
This doesn't work for me. There is no response when I press Alt + R.
tarafından
It works! I have a X541N, i just cleared the cmos password using this method. Thank you very much!
tarafından
Yorum Ekle
No response on ALT+R with an Asus X541SA
Puan 1
3 Yorum:
I'm having the same problem. I can get past my user password but not the admin and I've tried to Pastebin. The only option I know of is to send it to ASUS or replace the motherboard.
tarafından
tarafından
me too, solved?
tarafından
Yorum Ekle
Yanıtını ekle
Alex AWE sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 34
Her zaman: 4,620
