Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
Home button not working after EARPIECE replacement
So, I was given an iPhone 7 to repair which presented no sound or mic during calls.
Tested speaker phone and voice memo. Mic was working, as was the speaker. Diagnosed a faulty earpiece speaker.
Replaced the earpiece. Re-attached the LCD and camera flexes. Put battery + LCD shield back on, same with camera shield. Closed up and secured bottim screws.
4 minute job. All screws in correct place. Didn’t touch home button.
Booted phone. Tested calls. All work fine, issue resolved.
But… TOUCH ID not working, and unresponsive Home button. WTF??!!
Any ideas?
Bu iyi bir soru mu?
Puan 0
2 Yorum
Did you get an Error message. and did you disconect battery before you disconected anything else.
tarafından
Yes to both. I disconnected the battery upon oprning the phone. I was presented with " TouchID not available" on first boot after earpiece replacement.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
“The iPhone 7/8 series have a very inconvenient bend on the Home Button flex. It’s really easy to tear the flex, either near the logic board connector or at the 90 degree bend before it sneaks underneath the LCD heat shield. You have to be careful when you lift the screen off the first time but also anytime the flexes are connected and you have the device open.
You will need to carefully inspect the flex to see if there is any damage. Magnification here will help.  Look for tears to the flex or any physical signs of damage. You should also check the connector to insure none of the pins are damage or that there isn’t any debris.”
This is a cloned answer and all credits should go to @refectio , just to be clear, but I believe it may apply to your issue.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Checked home flex under scope -no tears, perfect condition.
Removed LCD (original) > checked connectors and board connections. No apparent damage.
tarafından
@firebug1302 Next step then would be testing mesa pins in diode mode compared to a known good one, can't see any other way if you already tried hard reset and a restore.
tarafından
Yorum Ekle
If you never removed the home button it may just need to be connected to Itunes. Not sure why but sometimes it needs to connect with itunes to clear the error.
Puan 0
Yorum Ekle
Yanıtını ekle
Charlie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 30
Her zaman: 511
