Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2264 Soru Tümünü görüntüle
iPhone 7 Stuck On Apple LOGO
Hi Guys.. Hi @refectio SIR
I have an iphone 7 (NOT water Damage). When i connect it to DCPS, show 0,22 0,23 amp, and stuck on these values.
There is only apple logo on the screen.
Dont restart, just stuck on apple logo.
Check Audio IC, but no improve.
The phone doesn't HOT, there is no short on the board.
I found only long screw damage near the battery, unfortuanlly i did'nt find nothing on ZXW about LSD on phone 7.
If i try to reset have error 9.
Is there any suggestion  plz?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Try replacing tristar as it can cause stuck on apple logo. I’ve had one point where it would have no display but show 0.17A on the DCPS, then pointed to a shorted tristar (it heated up a pad under the PMIC):
https://www.youtube.com/watch?v=mcUgeDTt... at start if video pretty much same short I had.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
My answer is replacing the battery. If you watch Hugh Jeffreys, you will know that he had the same problem with one of the iPhone 7 he was refurbishing. Your problem here is that your battery is dead and unable to charge. [Link removed]
After receiving the battery, find the right guide on ifixit.com and your iPhone will work!
Puan 1
2 Yorum:
So it might be a battery replacement problem ???
tarafından
I do a lot of fornite gaming on it. You think it might went bad i used it while charging all the time is that bad?
tarafından
Yorum Ekle
Thanks Everyone Guys.. its a Nand problem. I reball the Nand and phone turn on and work perfectly.. Thanks
Puan 0
Yorum Ekle
Yanıtını ekle
AGS sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 1,987
