Ana içeriğe geç
PlayStation 3 (veya daha sık bilinen adıyla PS3), Sony Computer Entertainment tarafından üretilen üçüncü ev bilgisayar eğlence sistemidir ve PlayStation 2'nin akabinde devamı olarak üretilmiştir. 11 Kasım 2006'da piyasaya sürüldü.
How to switch hard drive on different fat models?
I bought two broken fat ps3s off ebay, one had the broken motherboard and no display and the other one was missing a hard drive. I tried installing the hard drive from the first PS into the other one following the guide on this site but the systems have different connectors for the hard drives? The PS I took the drive out of had the connectors facing forward and the second PS had them to the left. How do I properly install the hard drive into the second PS? They are both fat models.
EDIT: The broken model I’m taking the drive from is a CECHL03 and the second is a CECHG03.
Bu iyi bir soru mu?
Puan 0
5 Yorum
@retroadvance
post some images of those connectors etc or at least give us the data label from both of those drives. They should all be SATA drives
tarafından
@oldturkey03 I only have one drive because the second PS3 came without one
tarafından
@retroadvance Duh, of course you are right :-). You mentioned that in your question. Can you post some pictures of the connectors? Here is the guide on how to post images Adding images to an existing question
tarafından
I'm not a ps3 expert however one seems to be a 40gb version and the other an 80gb version so I'm not sure if the drives are interchangeable so without pictures that may be the problem ur having
tarafından
Yes my fat. PlayStation 3 is a go1 and the drive comes straight out and goes straight in while my other fat model you have to move it left to come out and then back to right later for it to work why is that and in the first model I talked about above I want to replace the drive with a ssd drive but when I do it says it can’t find system on the drive but if I replace with 2.5 regular drive works fine what do I need to do to get it to work with ssd
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I’m speaking from some pretty rusty experience, but I believe that different PS3 fat models use the same types of hard drives (2.5” SATA) but in different orientations. Some versions of the console have the drive slide in with the connectors facing the direction of insertion, while others have the drive slide in with the connector on the side. For the later, you have to slide the drive in, then over to get it to engage. The drive is supposed to mount in a caddy, which slides into the system. If the caddy is missing (which I’m guessing yours is), it’s difficult but not impossible to get a drive into one of the sideways-mounted systems. I’ve used some folded up paper to hold the drive in place once I’ve finessed it into the connector.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Dan Rafter sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 771
