Ana içeriğe geç
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Soru Tümünü görüntüle
No clicks after battery replacement
I recently replaced both my battery and trackpad as the trackpad was not working and the battery was getting swell.
After I replaced the battery I get this problems:
  • Trackpad no clicks
  • Trackpad no touch to click
  • Trackpad still works with gestures, moving arrow, 3 fingers touch to search
  • External mouse only right click - no left click
I already tried:
  • Reconnecting the trackpad
  • Resettin NVRAM
  • Resetting SMC control
  • Deleting trackpad and mouse preferences files
  • Deleting general preferences files
What else can I try?
Thanks for helping!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Take the battery back out and then adjust the clicker plate stop
It hits the switch on the backside of the trackpad which is the click action.
You also might have an issue with the trackpads placement within the uppercase. I recommend placing a few posit note sheets around the edge of the case pasting them on the edge with the free side outwards so you can remove them along all four sides this makes sure you have an even gap around.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Ok I will try asap thanks for your help!
Anyway also the touch to click is not working. The option is correctly selected in the Mac settings though.
tarafından
Remember this is a mechanical switch (red circle) If you don't hear or feel the depression then you've over done the set screw setting.
tarafından
Thank you very much Dan, you solved it!
Great!
tarafından
Yorum Ekle
Does it click with the battery removed? Swelling batteries prevent the trackpad’s operation. Take the battery out and try without it.
Puan 0
1 Yorum:
The battery is new. And it does not even touch to click. And also no left click with the external mouse.
tarafından
Yorum Ekle
Yanıtını ekle
Ettore Stramignoni sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 208
