Ana içeriğe geç
Apple AirPods, Aralık 2016'da piyasaya sürülen kablosuz kulaklıklardır.
Case not working. Only when charging
My airpods case does not light up when I open the case. But if a put a charger in the light flashes white really fast. And my airpods is on right now and I don't know how to turn they off. Because my case doesn't do anything
Plz help
Bu iyi bir soru mu?
Puan 7
1 Yorum
Mine don’t even light up while charging
tarafından Paylaş
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
There may be a problem with your Airpods case then, and it probably can’t retain any charge, so, it only works when it is plugged in, when the energy is going purely into charging the airpods rather than charging the case.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
I my case, when it's plugged on charged, it show 100% of charge. I think that if it was a charge retention issue, it would display a critical level of charge instead of showing it fully charged.
One more thing, if I keep the box plugged, I am able to connect the airpods and they are fully charge too. If I remove the box from charge the airpods can't connect.
tarafından Paylaş
samething with ming
tarafından Paylaş
Yorum Ekle
My airpods have a orange light when they are charging but when i try to use them the light turns off and they won’t connect. I recently dropped my AirPods case and it has a scratch on it but I don’t think it’s that. Any tips?
Puan 1
1 Yorum:
I have the same issue too.
tarafından Paylaş
Yorum Ekle
You need to replace the case in this situation. I had faced the same problem and as my airpods were not under warranty, i need to pay 1200 indian rupees for the same.
Puan 0
1 Yorum:
yeah they told me the same thing, $179 USD (12603 Indian Rupees) to replace them
tarafından Paylaş
Yorum Ekle
In my nothing ear 1 charging case, TWS pogo pins are not working. is it possible to repair? Amy spare parts available? Please let me know
Puan 0
Yorum Ekle
for me was my connection pins in a case had corrosion after i rubbed votka and use my screw drive i was able to do the fix.
i know it sound bad advice.
Puan 0
Yorum Ekle
Yanıtını ekle
Isak_holmgard sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 34
Son 30 gün: 143
Her zaman: 62,275
