Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2264 Soru Tümünü görüntüle
facetime camera not working, earpiece is.
So, I replaced the camera lense on the main camera and after that, 4 days. the customer comes back, facetime camera does not work.
I have tried about 10 facetime flexes and no result on camera.
earspeaker, proximity sensor works perfectly.
What is this, how do I fix this?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It would be surprising if you had 10 defective FCAM flexes. Still, you should test them in another, known-good device to be certain. However, IMO, you have a logic board issue and you need to start investigating the FCAM circuit. Start with checking all the relevant power lines (see image below).
Then check the rest of the connector (J4503) against known-good values (ZXW).
Bu yanıt yardımcı oldu mu?
Puan 3
4 Yorum:
But is it possible for me to destroy something like that by replacing the lense of the main camera?
tarafından
My guess is possibly pry damage near the front camera connector? It would be small components around the FCAM connector that may be dislodged, missing or damaged.
tarafından
Than you so much, Minho and Ben.. I'll have a look after the customer resets the phone and brings it back.
tarafından
I'll update once I manage to fix it :)
With cause and fix :)
tarafından
Yorum Ekle
Yanıtını ekle
nicolay.94 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 95
