Ana içeriğe geç
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
20 Soru Tümünü görüntüle
Screen backlight flickers and goes off
Sometimes the screen backlight flickers of my Macbook Air mid 2013 (especially if backlight is set on low) and sometimes goes black after a while (I can still see the screen working, but without the backlight). What could be the problem and how can I fix it?
Please find a video here: https://photos.app.goo.gl/R1PwaJtE9fVWPF...
Many thanks for your help in advance!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
It’s hard to be of great help without any backgroud info, but picture clearly shows a backlight stage effect. It can be caused by a damaged screen cable, bad screen, bad connector on the logic board or an issue at backlight circuit on the logic board. You can try reseating the screen cable on its connector, but beside that, without known good parts to test or deeper diagnostic on the logic board there’s nothing else that can be done on a DiY basis. 13” screens for a A1466 are too expensive to just buy one risking it’s board issue in the end.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
I recently changed the battery and then after a few days this problem started, where can I find the connector/cable of the backlight screen? Is any guide on this to check if I accidentally touched the conector? Thanks
tarafından
Yorum Ekle
MacBooks aren’t my strong suite. But I’d suggest taking a look at the connection between the back-light and the motherboard.
Puan 0
Yorum Ekle
Yanıtını ekle
coen2019 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 204
