Ana içeriğe geç
Released alongside the AirPort Extreme base station, this hard drive equipped variant offers 802.11ac speed on a time capsule NAS.
56 Soru Tümünü görüntüle
Airport Time Capsule no longer connects to my network
My Airport Time Capsule no longer connects to my network. I was told that there is a chance the hard drive can be taken out and the data might be able to be saved to another drive. I have no idea where to start. I don’t care if the actual Time Capsule is torn apart as the TC is no longer of use to me. I downloaded your instructions on how to take it apart. Do I have to be careful as far as disconnecting the cables and power connector?
What do I need to purchase so that I can attach the TC hard drive to my MacBook?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
A 3.5” hard drive is used in the Time Capsule.
You'll need a 3.5” hard drive dock that is externally powered and provides USB connection.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
This is the SATA to USB adapter yo are speaking about StarTech 2.5" SATA to USB adapter cable
You'll need some recovery software to pull the data off as the files structure of the drive is not MacOS compatible.
tarafından
Hmm. It's a 3.5mm hard drive installed though so the adapter won't have enough power to get the hard drive working off that adapter.
tarafından
Good point! You'll need one with a power assist (external power)
tarafından
Yorum Ekle
Yanıtını ekle
Menthia Carpenter sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 89
