Ana içeriğe geç
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Soru Tümünü görüntüle
CDMA vs GSM replacement back cover
Whats the difference between a CDMA iPhone and a GSM iPhone back cover? Why is a GSM replacement cover not compatible with the CDMA? Do you thinks its possible to make it compatible by removing some of the mounting clips or something else?
Bu iyi bir soru mu?
Puan 1
1 Yorum
To my knowledge they should both be compatible with each other? The only differences in the models are small hardware changes (logic board) and a different roaming frequency. Have you tried a GSM back cover on a CDMA iPhone or vice versa?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The iPhone 4 GSM and CDMA back covers are different. The mounting frame scew mounts are spaced very differently.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
there's no physical difference between 4s and cdma, the difference is in the writing on the back.
CDMA is 2422
4s is 2430
Check us out on SPAM REMOVED
Puan 0
1 Yorum:
jobo, you need to read the question before posting Spam. The question does nowhere mention a 4S. If you want to become a better spammer, you need to learn that the 4S is a GSM/CDMA (remember the term "world phone") Oh my, you still have a lot to learn little grasshopper. Good luck in your other job, hope you are better at that.
tarafından
Yorum Ekle
Yanıtını ekle
Perry sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 4,876
