Ana içeriğe geç
Sony Cyber-shot DSC-W830, durağan görüntüler ve 720 piksele kadar video kaydı yakalamak için tasarlanmış 20,1 megapiksellik bir fotoğraf makinesidir.
SD card write protected
my SD card is write protected so I can’t take pictures. It happens with every SD card I use. The physical write protection is turned off, I can’t reformat the card because I just get a pop up that says the SD card is write-protected.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Can you format the SD Card in a computer and then try it in the camera?
If it still fails, it appears as though the contact in the SD Card reader in the camera, that detects the position of the lock switch on the SD Card may be bent or stuck, indicating the card is locked when it isn't.
You’ll probably have to open the camera to access the SD card reader and most probably have to replace it.
Here’s a link to the ifixit Sony Cybershot DSC-W830 anakart değişimi guide which may be of some help in gaining access to the card reader.
If this seems too daunting, contact a reputable, professional camera repair service and ask for a quote
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I put the card in the computer, but it still failed in the camera. So I will follow up on this solution. Thanks!
tarafından
Yorum Ekle
Yanıtını ekle
tagarrison sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 27
Her zaman: 751
