Hi,
You can’t move the system apps over to the SD Card but there are other things that you can do to improve the storage problems.
a). You can try to move your downloaded apps to the SD card (and perhaps some pre loaded apps as well) but it depends if the app developer has enabled the function when the app was first created.
To do this go to Apps > Settings > Device > Applications > Applications Manager and tap on a downloaded app. In the options that open there should be a Storage setting to manage the app’s location, either in internal storage or SD card. If the option is greyed out or not there the developer has not allowed the move. Do this for all your downloaded apps.
b). According to the specifications for your phone it has Android 6.0 installed so you should be able to use the SD card (max cap. 128GB) as internal storage (combine internal storage with SD card storage), using the Adoptable Storage facility provided by the OS. Read through the article as there are downsides to doing this.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
2
