Ana içeriğe geç
The Nimbus is a wireless game controller released in 2016. It is designed to be compatible with the iPhone, iPad, iPod Touch, Apple TV, and the Mac.
My right analog stick gets stuck when I move it right.
Every time I move my right analog stick to the right, it gets stuck. Can someone help?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi
I would suggest you to open up to check if there are any debris stuck inside.
Unsticking SteelSeries Nimbus Triggers
you might need to apply a little wd-40 inside
else if it does not works well, you will need to find replacement from ebay / aliexpress for parts.
you need to desolder and solder on the new part.
Below are example of parts which i take from xbox, it can be a different manufacturer, suggest you to open and check.
https://www.aliexpress.com/item/32319475...
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
The AXIS has two clips on each side attached to the thumb sticks.
It has 3 pin for bi-direction. (left right or up down)
You can use a multimeter tip or small metal clip to bridge the 1 2 3 pins between one another and the signal
will do left right or up down.
I used a app on the device as I was trouble shooting to watch the stick movements and once I came across this
article and was able to get the correct part name, I was able to see how this axis part actually worked an gave it a shot.
Inside the axis is a aluminum discs with a plastic mold.
I had to reseat the disk using tweezer.
(This requires some slow movement as you remove it or reseat it as the metal is very thin)
This allowed the analog stick to zero/center itself and didn't keep it stuck to one direction again once you moved it.
I found a replacement part at DigiKey "THUMBSTICK DUAL AXIS" was the search term for a proper donor
part fix to replace the fault axis sensor as the SteelSeries Nimbus analog thumb is imbedded to the rocker and
not screw affixed so it wasn’t changeable.
I'm not sure how long the temp fix is gonna last.. (going on two days now).
So best to replace the axis sensor at some point without having to mess with thin disk as a backup plan.
But this worked for me while the part to come via snail mail.
Puan 0
Yorum Ekle
Yanıtını ekle
tR4Sh_Alex sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 38
Son 30 gün: 113
Her zaman: 11,769
