Ana içeriğe geç
Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
136 Soru Tümünü görüntüle
When I try to start the engine it will not start all I hear is a noise
I have an old Murray rider that was given to me by a friend the model number is283707. This is the model number from the small plate on the engine. I try to start it and it does not start, all I hear is a zinging noise. Is this the starter or solenoid?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
A “zinging noise” is probably the starter gear not quite meshing with the flywheel’s ring gear. First make sure the battery is fully charged and does not sag too much under load. Many of these small engines don’t use a solenoid, instead they have a bendix gear that uses inertia to accomplish the same task. These types of starters are very sensitive to weak batteries. I would even try jumping it from a running car.
If that doesn’t help, the next step is to turn the engine by hand about a quarter turn, then try the starter. This is to check the ring gear, most engines will always stop at the same place, so the starter usually hits the ring gear in that one place. Rotating the crank a few degrees exposes newer gear teeth to the starter. If that gets the starter to engage, or engage for most of a turn and then resume zinging, you need to replace the ring gear on the flywheel (or get used to turning it by hand a bit before hitting the starter).
If you made it this far and haven’t found the problem yet, pull the starter and either replace or repair it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Ksondra moore sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 33
