Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
2690 Soru Tümünü görüntüle
iPhone wont turn on after screen and battery replacement
backstory on iPhone: I dropped my phone a few weeks back and the screen smashed and touch stopped working I was using another phone as a replacement and let the broken phone die when I tried to charge it to turn it on there was no sign of life not even red battery logo. I have just changed the screen and battery and the phone will not turn on.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
It’s either a replacement parts issue or a logic board issue. When repairing devices, it’s important to have good quality (preferably known-good) replacement parts. Does the phone have the same symptoms with the original screen and battery? If so, then it may be a logic board issue that was caused by the drop.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
If you only have a screen problem, you should be able to turn on the phone and use the mute switch a few times to see if the phone vibrates.
Puan 0
Yorum Ekle
Yanıtını ekle
eimearw565 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 30
