Replacement for the power ribbon cable in Sony Vaio laptop
Hi,
I have Sony Vaio svf13n12SGS. I want to replace the power cable. However, I could not find same cable with exactly same numbers. This is what I found : 8pin AWM 20624 80c 60v VW-1 15cm, while, the original cable is: Kotel E220709 8pin AWM 20798 80c 60v VW-1 15cm. Please check the attached photos.
Can I use this cable (the new one) or it must be exactly like the original one?
Update (07/31/2019)
Hi @jayeff
Thank you very much for your help. This is first time I do this type of work and I don't have any experience. All what I need is determining the right cable. Then I will find a way to replace the cable.
Could you please check the attached photo, it shows the width of the original cable.
Bu iyi bir soru mu?
1 Yorum
@jayeff
Thank you for your reply. The pitch in the original cable is it 0.5mm or 1.0mm?
shdotcom tarafından
