Ana içeriğe geç
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Soru Tümünü görüntüle
phone wont turn on shattered screen
phone got thrown the lcd screen is busted , it showed a bunch of different colors. the phone powered off and now wont power on. will replacing the screen make it turn on, or is it something else?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The first thing to do is to totally disconnect the screen (always disconnect the battery first!). Then connect the battery back to the logic board and then connect the phone to an iTunes enabled computer to see if it is recognized. If it is, then you may only have a screen issue. If it isn’t, then you may have a logic board issue.
The heat concerns me as that is not normal, even with a busted screen. It could be caused by a bad FCAM flex or a damaged screen. However, if these variables are removed and the phone still doesn’t boot, then consider having this looked at by an experienced micro-solderer.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
jordancauvel1998 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 62
