Ana içeriğe geç
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Battery replacement odd behavior
Hello IFIXIT community,
I recently bought the MacBook Pro replacement battery kit that IFIXIT provides to their customers so they can do Apple’s job at a cheaper price. I was able to install the battery with no issues at all.
But, after a day, while using my computer after calibrating the battery for better results I decided to restart the laptop for some testing not related to its battery life. Before I rebooted, the machine life was at 69% but after turning it back on, the battery was showing me a 6% battery life which is super odd and insane at the same time.
If there is anyone that experienced this with their replacement and/or noticed but went away later after constantly using the machine, please let me know. I am an IT guy myself, but I do want to make sure I am not the only one that has seen this odd behavior on a computer.
I hope that somebody can share any thoughts and or a solution to this. In the meantime, I will disconnect the battery adapter and put it back in just to see if it is just a mistake I made.
Hope somebody answers soon. Cheers community!!
Bu iyi bir soru mu?
Puan 2
9 Yorum
Please post a snapshot of CoconutBattery so we can see the batteries status Adding images to an existing question
tarafından
Hello Dan,
Thank you for commenting on my post. I have edited the content and the image should be now displayed. To me everything looks fine on the battery, also checked other battery apps while waiting for this response last night. Is there anything in mind that could be causing this?
tarafından
@danj Today while using two different battery use checkers or whatever you want to call them, I noticed that they provide different numbers from the battery's charge for example:
The mac battery shows 73% and so does the app "Battery Monitor". While coconut battery shows 67% and the mac battery shows 73%.
Do you have any idea why this could be?
Thank you
tarafından
@poporobright Coconut battery always shows a lower percentage except for when battery is fully charged.
tarafından
@arbaman - Correct! This is mostly do to the lag between the OS call to SMC from the app and its reply. Unlike the OS's native access to SMC.
tarafından
4 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The CoconutBattery output looks good!
Its what I would expect. How about cleaning the MagSafe connections in case your one-wire sense line was not making good contact. Review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters. Make sure the cable is not damaged in any way, also make sure you have a real Apple charger! There are many fakes out there that will damage your system OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth.
See if after cleaning the connections and if needed a replacement charger fixes things.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Hey Dan,
Thanks for all the support. I got this mac charger from my tech company so I genuinely think it is a true mac charger. Also, I will clean the port and see if it keeps changing and or getting better while I continue to use it.
Will keep you posted .
Thank you
tarafından
@poporobright If the Mag-Safe does not have an Apple logo stamped into both sides it is a knockoff and may damage your Mac
tarafından
@mayer thank you for the info!
tarafından
Yorum Ekle
Yanıtını ekle
Daniel Mazariego sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 103
Her zaman: 556
