Ana içeriğe geç
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Soru Tümünü görüntüle
My cable got heated and then the phone display worked but wont charge
My cable got heated and burnt.. i took it off immediately the display showed charge battery But the charging port isn’t working, what are all the possibilities that can be caused..?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
There’s a good chance that the phone sustained some extensive damage. However, without knowing if the issue is caused by a bad charger/cable or a logic board issue, it’s hard to say what exactly is at play.
You’ll need to consider that the charge port and/or battery could have been damaged in the process so you’ll need to eliminate those possibilities before looking at potential logic board issues. On the logic board, you could have a damaged Tristar/Tigris IC’s.
Open up the phone and measure the voltage of the battery to see if it is still good. If it measures 0V, you’ll need to get a replacement. Try charging with an original and preferably known-good charger and cable to see how the phone behaves. A USB Ammeter will tell you if current is flowing or not. The next step is to try a known-good (or high quality replacement part) charge port and do the same tests. If the phone still doesn’t work/charge, then it will require a micro-soldering repair.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
rufus vergis abraham sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 60
