Ana içeriğe geç
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
20 Soru Tümünü görüntüle
MacBook Air mid-2012: Random screen glitches and lockup/crashing
Hi iFixit community,
I have a problem. Seemingly at random, my mid-2012 Macbook Air locks up, the screen glitches out, and quickly crashes. When the speakers are on, I also get some awful sounds coming out. This happens regardless of being plugged into power or not, though it does seem to occur more rapidly while on battery. I’ve attached a video of the strange behavior.
I had previously (and carefully!) replaced the SSD and battery to keep it alive a few years back. Thinking those components might’ve been the culprit, I recently re-replaced both. It’s currently sporting an OWC SSD and fresh battery from iFixit.
I’ve tried looking in the machine logs and can’t find anything particularly useful. I’ve reset the SMC and PRAM many times. I’ve reinstalled a fresh MacOS just to be sure it wasn’t something weird in the kernel. Sadly, none of that has worked.
Anyone seen this before, or any ideas about what’s going on? Can I revive my favorite little computer?
Thanks folks!
Updates (from tests in comments):
  • Model is an A1466, so mid-late 2012
  • In addition to the issue happening on the built in display, it also occurs when using an external monitor exclusively (lid closed).
  • Running a GPU benchmark tool did not crash it outright.
Bu iyi bir soru mu?
Puan 0
6 Yorum
@mattwilson - Your system is part of this series A1466 and more precisely MacBookAir5,2 - Mid 2012 models
You will see all of these use the Intel graphics engine: HD Graphics 4000 which is part of the CPU module. None of the Airs use dedicated GPU's like the Pro models do.
tarafından
I have exactly the same problem. My mac air is also mid-2012. Sometimes it flickers and crashes at the login screen, sometimes it runs several days without any problem. It is really random and tried many things but couldn’t fix the problem. Is there any new comments or suggestions on this issue ?
tarafından
I experienced the same thing with my mid 2012 MacBook Air luckily I upgraded to a 2019 MacBook Pro 13
tarafından
Is there a way that you can take the bad GPU and put in a other one like it alright soldier in but. I’m wondering if u could unsolider it and responder the new on to it.
tarafından
Resolider the new on to it with the old one?
tarafından
1 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Unfortunately that looks like a GPU failure. If it’s an A1369 from early 2012 it’s a typical issue, less frequent on 2012 A1466 but it may still happen. You can download and run a benchmarking App like Valley from Unigine, that would cause a repeated reboot or shutdown as soon as launched and would confirm the GPU failure. I’d recommend backing up your data before that, as the board may brick for good anytime.
Bu yanıt yardımcı oldu mu?
Puan 0
13 Yorum:
Ah, dang. It is an A1466 so here's hoping. I've downloaded and run that benchmark tool, but didn't experience a crash when using it, actually ran it for a few minutes with no issues. So, inconclusive on the GPU status I guess.
tarafından
@mattwilson If it just happens with closed lid and connected to an external screen that changes considerably the picture you initially described. It points more to a thunderbolt issue, nothing I would be happy to deal with at board level either. I don't think there's much you can do even in this case except avoiding to close lid ;)
tarafından
Oh, it happens either way! I meant that as it happens the built-in display, or a connected display running as the sole screen.
But I suspect you may be right regardless...
tarafından
@arbaman - The air systems use the built-in graphics engine within the CPU chip. The issue here is either the fan, heat sink or the thermal paste has failed if it can start up cleanly cold and then get into this state. Otherwise the logic board will need replacing.
tarafından
@danj I believe it's easier for a user to understand the concept of GPU without going into deep technicalities. In this case the main chip is a CPU/PCH of which the PCH part takes care among other tasks about the graphics too.
tarafından
8 tane daha yorum göster
Yorum Ekle
I have this problem with my laptop and I was thinking out just soldering a new one to broad itself. Bc I try repasting and and look up what can cause this and every thing says it the GPU or CPU chip that is the cause of it. So if the chip is failure maybe just solder another to it.
Puan 0
Yorum Ekle
https://discussions.apple.com/thread/251...
Apple says it's a hardware failure, which is actually a plausible explanation.
But... this crash never, never happens, under Windows which I use often and for a very long time.
The crash also occurs sporadically with a freshly installed Mojave, and with Catalina as well.
But this crash also never occurs with an OCLP-patched Ventura.
Could it be that the standard Mojave/Catalina video driver is a bit sensitive when deviating from tolerances?
...and another video driver is less critical?
Then OCLP and newer versions of macOS might be the answer.
Anyway, it works for me !.
Puan 0
Yorum Ekle
Yanıtını ekle
Matt W sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 33
Her zaman: 2,646
