Ana içeriğe geç
Microsoft's third-generation Xbox game console, released November 22, 2013.
727 Soru Tümünü görüntüle
How do you know if the optical disk drive is the same as the motherboa
Say you buy optical disk drive off of Amazon and when you get it has the daughterboard and everything but it’s not the same as the original daughterboard that was in the previous optical disk drive you had in the Xbox. How do you know if the daughterboard and motherboard are the same?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
You mark the drive board as original before changing out the laser. What I would do so desolder the motor cables and transfer the board only if it came as a whole drive.
Otherwise I would do a laser caddy transplant which involves removing the 4 screws that go on the rubber standoffs. To remove the whole laser assembly in one go.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
You need to check the models of the drivee before buying one. There can be several OEM vendors supplying Xbox One disc drives and each vendor may have several models. Drives of different models obviously won’t have the same controller board and will not work.
Puan 2
Yorum Ekle
Yanıtını ekle
John sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 47
