iPhone can't restore to factory defaults settings error message 2006
I put my Iphone in the washer stop working properly I can’t restore with iTunes error message 2006.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The proper way to treat a wet phone is to do the following:
You should also replace the battery if it has swollen. Resist the temptation to pop it to let the gas out. A compromised Li-ion battery is a fire hazard. If the device appears to power up but behaves erratically, then use a tool like 3uTools to flash the firmware as it may be corrupted.
A professional repair shop that does water damage repair may be able to recover your data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no data/no fee policy so you don't have to spend money to find out if the data is recoverable or not.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 81
1 Yorum
Electronics Water Damage
prop man tarafından
