My MacBook Air loops in chime sound and wont boot up
Hi My Macbook air 2015 keeps on loop chime on boot up…
1 Should i try to boot from a usb just to isolate the flash ssd.?
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
Hello. First you’ll need to find what exactly is wrong. It could be many things (Motherboard, SSD, NVRAM etc) First try resetting the NVRAM:
If this doesn’t work, try booting from the recovery:
If the recovery doesn’t even boot then there is something else wrong perhaps the motherboard.
Bu yanıt yardımcı oldu mu?
Hi … Sorry but non og the above suggestions helped… What to do know.. I dont want to buy a new flash ssd just to find out that there is a issue with the motherboard… Should I try to booth from a usb stick..?
please help
Did the recovery boot? If it did then that proves the motherboard is fine and it just can’t boot anything from the SSD. Yes if you want you could boot from a USB because that would also prove that the computer is fine, just not the SSD
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 105
