Ana içeriğe geç
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1698 Soru Tümünü görüntüle
Why is moisture forming between my ice marker and door gasket?
Recently we have noticed a lot of moisture forming around the gasket between the door and ice maker. We are constantly making sure the door is closed throughout the day and it still happens.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Damaged or worn seals around the door that are leaking cold air, or because the temperature is set to be too cold
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I overheard a guy talking about something you add on refrigerator to prevent that from happening , ask something like a heat module to prevent condensation
Puan 0
Yorum Ekle
Yanıtını ekle
Kevin Tomyk sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 6
Her zaman: 42
