Ana içeriğe geç
4 Kasım 2017'de satışa sunulmuştur. Model A1865, A1901. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Gümüş ya da Uzay Grisi renklerinde satılır. ("iPhone 10" olarak da telaffuz edilir.)
1199 Soru Tümünü görüntüle
iPhone X no power
Help! My wife’s iPhone X recently went to 1% battery, died and now won’t turn on or show any signs of life. I ordered a replacement battery on this website and successfully installed it but it didn’t fix the issue. I’ve tried the hard reset sequence also with no luck. Do I now have a $1000 paperweight? I would really appreciate any guidance given.
Thanks!
Jason
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
What happened in the days leading up to this issue; was the phone dropped, repaired or came into contact with water?
This could be as simple as a bad battery (although iFixit batteries are usually very good) or it could be a logic board issue. You could try disconnecting the screen and cameras from the logic board (battery first!), leaving only the board, dock flex and battery and then see if the phone will be recognized by an iTunes enabled computer. If it doesn’t see the phone, then it is most likely a logic board issue. If the phone does boot, then add one flex at a time until it stops working to determine the faulty part (again, always disconnect the battery).
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
There were zero issues with it before this happened, just normal use with no dropping or water. Ok thank you! I'll give it a try today!
tarafından
Yorum Ekle
How long have you owned the device for? If you've owned it for under a year, go to Apple and they will replace it with a new one as long as there's no physical damage and as long as it hasn't been serviced anywhere. If no warranty or apple care I'd recommend minhos answer.
Puan 0
Yorum Ekle
Yanıtını ekle
Jason Miner sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 129
