Ana içeriğe geç
The Pixel 3a XL is the larger version of Google's third generation budget phones, and includes the same camera as Google's flagships. Available in Clearly White, Just Black, or Purple-ish. Released May 2019.
15 Soru Tümünü görüntüle
When I turn my screen off and back on screen becomes unresponsive.
I recently replaced my screen and when I first turn it on everything works fine, but when I turn off the screen and then turn it back on, everywhere I touch just brings up the pull down menu.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
1 Yorum
TO the original poster, I am facing the exact same issue after replacing my broken screen, were you able to find a fix for your issue?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
To anyone facing this issue, the problem seems to lie in the replacement screens themselves. A workaround is to go into Settings > System > Gestures and turn OFF “Double Tap To Check Phone"
After turning this gesture off, the phone works normally.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
This sounds like a faulty display assembly or possibly even just a poorly seated cable. If you can, try to pop off the display connector and give both sides a gentle clean with some high % isopropyl alcohol. If the screen is still unresponsive, it’s likely to be a bad display assembly.
And unfortunately if the same behavior is present on multiple displays, it’s possible the board was damaged somehow during repair, in which case, you may want to look for a new device or send it to a board repair service.
Puan 0
Yorum Ekle
Puan 0
Yorum Ekle
Yanıtını ekle
Sany Dan Muk sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 9
Son 30 gün: 13
Her zaman: 378
