Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
2193 Soru Tümünü görüntüle
Part of screen not working, same with lock button! Help!
My lock button hasn’t worked for a while but randomly the left lower part of the screen stopped responding to touch. I can’t unlock my phone because of my passcode and I can’t reset my phone either because assistive touch is located where the screen doesn’t work! What can I do?!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I think you need a new screen. The repair guide lists the job as Difficult and there’s a lot of disassembly to do, but don’t be put off. So long as you’re well organised, make sure you note which particular screws came out in which steps so you can put them back correctly, and you have a fair bit of patience, it isn’t that hard. You just have to be very careful feeding the LCD and touchscreen cables through a slot in the midframe as there is a weak point on the inside of a bend in the ribbon where they can very easily tear. Having removed the old screen, practice reinstalling and removing it until you’ve mastered it before risking the new screen.
Or, you can take it into a shop - at that age the screen won’t be too expensive and it’ll be a fairly standard job for an experienced repair technician.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Mare lynch sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 37
