Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
2690 Soru Tümünü görüntüle
iPhone 6s Water damaged, drawing 0.435A
Hi everyone, was hoping someone would be able to help with regards to fault finding.
I have a water damaged iPhone 6s, that with a known good battery in will draw exactly 0.435A when plugged in and just sits there, I get no display and nothing else happens.
With regards to finding the fault, where would I start?
Thank you
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I am not sure what equipment you have to diagnose the problem. Assuming you have the bare minimum.
1.       It most likely has a short so we need to find what power rail.
2.       Find the schematics for the phone.
3.       Remove the board from the housing.
4.       Start diode mode testing with your multimeter.
Compare readings with a good phone and let us know what you find.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Phone Improvements sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 37
