Hi @zdaar ,
If the indications are that it is not charging correctly then there may be a problem with the circuits that charge the battery and/or run the laptop when the charger is connected.
To trace this circuit you’ll need access to the schematic for the motherboard as it will be extremely difficult without it. You may be lucky to spot an obviously faulty component on the board but maybe not.
Try searching online for (insert motherboard board number) schematic to see if you get any results.
Here are some ways to maybe check IF the battery is being charged properly or not contrary to indications.
Here’s a link to the hardware maintenance manual for your laptop, taken from this webpage
Scroll to the section Checking the built-in battery and operational charging, on p.29-30 to view the procedure to check the battery pack.
Try using this software -example only and check if you can see what’s happening with the battery when the charger is connected and switched on.
Try using HP’s Diagnostics Custom Scan > customize > battery > Scan selected and follow the prompts, and check the results.
You may have more than one fault i.e. faulty charging circuit and a faulty battery or maybe the battery is now faulty due to a faulty charging circuit.
Have you got the latest power management drivers and BIOS firmware installed? Just a thought.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
2
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
