Ana içeriğe geç
Model A1625. 2015 revision to Apple's set-top-box featuring an A8 processor and 2 GB of RAM.
Replacing the wifi chip in my Apple TV 4
Hi,
My Apple TV 4 has a defective bluetooth/wifi chip. So I found one on eBay, a 339S00045 chip, which seems to be the same as in the ipad mini and pro. I took my apple tv apart, but the chip doesn’t seem to be that easy to replace. Is that something that is even possible at this point?
Regards,
Pieltre
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Sadly this is a BGA chip which really needs a proper rework station to fix.
Basically, after you carefully remove the old chip you would clean the old solder off clean the board and then using a mask and the correct sized solder balls layout the field and then reflow the chip back on.
Given the cost of the needed equipment and sundries. I think it will be cheaper just getting a new Apple TV ;-{
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
You cannot replace the WiFi chip as its paired, tried already. no way to get the device into DFU to restore either
Puan 0
Yorum Ekle
Yanıtını ekle
Jean Maxime Lachance sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 21
Her zaman: 676
