Ana içeriğe geç
2013 yılında piyasaya sürülen 14 inç dizüstü bilgisayar
Can this be repaired SIM card circuitry
https://ibb.co/rbTXjCn
https://ibb.co/yNt75LZ
https://ibb.co/xmr3GSf
I inserted a wrong misfit sim card tray into my Thinkpad T440. The tray engaged into interlocked i could not pull out. After I pull out with a certain amount of force, I pulled out the sim card tray and along the above gold metals. I feel really stupid. Can this be repaired?
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
The SIM card reader is mounted on the systemboard.
To gain access to the SIM reader you’ll need to remove the systemboard.
Here’s a link to the hardware maintenance manual for your laptop, taken from this webpage (select p.2 at bottom of list and then scroll down to find the entry)
Scroll to p.86 to view the necessary pre-requisite steps and then the procedure to remove the systemboard.
That was the easy part.
Once you have access to the reader you’ll have to determine what type and configuration of SIM reader was used and then try to find a compatible replacement part. (I cannot find any information, part numbers, brand name etc, as to what type was used)
Once you have the part you’ll need SMD (surface mounted device) soldering tools and skills to effect the repair.
Perhaps it may be easier to take the laptop to an authorized Lenovo service repair centre and ask for a quote to replace the SIM card reader. They may have access to more information regarding the SIM reader etc and also the necessary tools and expertise to perform the repair.
You may be able to lower the cost of the repair by taking just the systemboard, thereby reducing the labour cost by reducing the amount of time that the repairer spends in dis-assembly and re-assembly of the laptop. The downside of this is that the repairer can’t test the repair and ensure that you have a fully working laptop upon completion and perhaps will offer no guarantee.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
If you can solder, then you could try to fix the contacts.
From the looks of that motherboard on eBay, you will have to taker the motherboard out.
According to T440s fru_list, SIM tray is a separate part(Its FRU 04X5345, description is “SIM Tray”), but it isn't CRU (customer replaceable unit) in the parts_list.
I suspect that Lenovo won't/can't do it because their repair facilities don't have the necessary equipment and skills. You may find a local PC repair shop or similar facility that specializes in doing such precision work.
While the problem came to SIM card reader, you should be careful as it is a more precision work.
Puan 1
2 Yorum:
Hi @v3nuo ,
I had looked at the part number (04X5345) as well but it is as described in the parts list, a SIM TRAY and not the SIM card reader.
tarafından
@jayeff Yes, you are right, sim reader isn't a separate part, it should be soldered on the laptop system board, and that's why the reader isn't CRU (customer replaceable unit) in the parts_list as well, thanks for the reminder.
tarafından
Yorum Ekle
Hello!
I have the similar problem - I bought a T440p with a messed up sim card slot. It looked terrible, I decided to remove everything….but I wonder what I could replace it with now.
@jayeff: Do you have an idea which (maybe non-Lenovo) part could be soldered here?
Resim
Resim
Puan 0
2 Yorum:
Hi,
I'm fairly sure that a non Lenovo SIM reader port could be used but the hard part is knowing which SIM card reader -examples only would be compatible with the motherboard.
Factors to take into account would be the reader's mounting lug position to that of the pads provided on the motherboard.
The pitch of the reader's pins i.e. distance apart so that they match the motherboard.
The type of SIM Card reader, Standard, Mini or Micro.
Do you still have the old reader and are there any markings on it which may identify the manufacturer of the component? This may help as perhaps you could search their website for a suitable replacement.
Also try searching for the motherboard service manual i.e search for "(insert motherboard 'board number") schematics or manual" etc, sometimes these types of manuals contain a parts list which may be of some help.
I did try looking for "faulty" motherboards for your model and thought if the price was OK and they had a SIM reader shown in the image that it may be worth the gamble to get one as a "donor" board for the part but most all that I found showed no reader port in the image posted. The gamble being of course that the reader was OK as the owner might not have used it. Just an option to consider if you're having trouble locating a replacement.
That's all that I can think of at the moment.
tarafından
Thanks for your reply - I ordered a faulty board and will see how the intact sim card socket looks like. Most likely I will destroy it while removing it, though. Some parts of the socket on my board were really sticky even after heating it up, maybe it's impossible to remove it without deformation/partly destruction from the faulty board. But at least I will know how the intact socket will look like - maybe I find it on Mouser or elsewhere)
tarafından
Yorum Ekle
For most people, it’s not the end of the world outside of hurting the resale value. For example: I don’t want a WWAN card on most Lenovo laptops after it’s ~18 months old or it just has to come with the deal - that’s because many of them tend to use older network technologies that are close to death, especially pre XX40 models. The cards are whitelisted, so I can’t decide that the cards sanctioned by Lenovo are too old to bother with, but I can buy any card I like as I can with a Dell Latitude. It’s generally not something that’s cared for after it gets to be too old.
In this laptop, the current card the US models use is the Sierra Wireless EM7355 (FRU: 04W3801). It’s an LTE card (which is good) and outside of regional issues one card is used with these machines so it’s nowhere near as bad, but even then it’s not something people always care about - especially if you take my attitude and don’t care if it comes with one, but if it doesn’t NBD. In the past, it was done with a few specific cards and after 18-24 months, they’re all either dated and not worth having (unless you NEED IT) or in the case of a 36+ month machine, all obsolete (usually 3G GSM or CDMA). On top of that, the cards are highly regionalized - not an issue for most but can be a pain for travelers. I have yet to buy ex business hardware where someone sunk money into WWAN hardware - much less find it in the hardware roster. It’s that rare of an option.
I have the same rule with Dells but to a lesser degree since they don’t have a WWAN WL and if I can use it, I can fit something like an E6X40 card in the same PCIe slot if it’s known to be technologically compatible; I draw the line when the laptop is so old it’s MiniSIM based like the E6X20/30 series.
Unless you NEED a WWAN card, I wouldn’t risk it over a part few people seldom care about after 24-36 months. Get a MiFi hotspot if you really need it like the rest of us with old laptops who want a backup. You’re at 96 months/8 years with this, so you’re at the point buyers like me will just ask for a price break and use a MiFi hotspot the one or two times per year they probably need it. You may not even be ABLE to buy it anymore and unlike old machines, you can’t flash the BIOS - Intel Boot Guard ruined that. Are you doing this to protect yourself from losing $50-60 worth of lost resale value (which will be completely lost if you ruin it since it’ll be a parts machine) or do you need it?
Puan 0
2 Yorum:
Thanks - there is WiFi almost everywhere nowadays, mobile hotspots, etc. Surely, there is no need to fix it, but rather the challenge to get it done.
Also, there are PCI adaptor cards with slots for a WWAN card AND a sim card socket as a workaround for T430, etc., but I could not find any such adaptor+sim card socket for M.2/T440p.
I'll guess I'll just try to find a similar-looking sim card socket after I inspected the faulty mainboard I ordered - and hope I will get it soldered at the right spot)
tarafından
@Cla Gaw Up until the XX30, you could mod it out entirely - but a lot of the BIOSes leave the WWAN WL in IIRC - the Middleton BIOS (most common) mentions WLAN and not WWAN so I'm thinking they just remove the WLAN one and keep the WWAN one. That changed with these as I said. Maybe Middleton removes *both* but you want to ask and see if you want to remove the WWAN WL since even the modders don't care about it as much as the WLAN one.
It doesn't exist here because the workaround is a custom BIOS - blame Intel for that.
A lot of the time you see these questions, people want to do it to protect a small amount of residual resale when that means risking it all because losing $60 is more painful then 80-90% of it.
tarafından
Yorum Ekle
I fixed one myself using an heat gun and soldering iron, hard part is stripping the laptop then removing the metal cage around the sim card tray, the gold contacts are easy enough to solder on and off, i looked at many old phone sim card contacts to find a useable replacment , i broke off 3 and fixed mine. just hope you havent broken the contacts and need to make tracers to the pads pulled off,
If youre lucky its just a pin like this https://youtu.be/UW80B6OXdpg
Any phone sim card contacts will work : example of whats needed here https://youtu.be/zF2IoWP_vg0
Puan 0
Yorum Ekle
Yanıtını ekle
Dexter Aparicio sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 2,090
