Why is my Soundfreaq sound kick not charging?
After long frequent use, the speaker no longer charging and power light not turning on, cord fits loosely. I opened up and no apparent damage. Suggestions?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@ilovelucy24680 check the charging port for power when you have the charger plugged in. It is possible that the port simply wore out. To replace it you would need to measure it etc. and use that information to try and match one with some ports available at mouser.com or digikey.com. Also, replace the battery while you are at it. Use this teardown to get into it. Use this Adding images to an existing question to add your images if you need further help, with your QUESTION.
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
Kılavuz
Zorluk:
Orta
15 minutes
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 1,665
