Ana içeriğe geç
Repair guides and support for the fourth generation of Ford Mustang, including the Mustang GT and Mustang Cobra.
20 Soru Tümünü görüntüle
Why is my Battery Draining
If I don’t start my 04 Mustang Mach I in two days, the battery is dead. Pulled individual fuses, no problem. Pulled the #6 High Currency Fuse (located by the battery) and the draw stops. #6 controls the Powertrain Control Module (replaced with a reman with plug and play), I/P Fuse panel and Instrument Cluster. I’ve called three Ford Dealerships and Ford Motor Company who could not provide me with any information as to what the I/P Fuse panel is or where it is located in order to determine if there is a short. Can you help?
Bu iyi bir soru mu?
Puan 4
8 Yorum
I have the same problem with my 2003 SVT Cobra, if I let my car sit for 3-4 days my battery will die. Changed the battery and had the alternator rebuilt but the battery will still drain . I suspect the voltage regulator might be faulty.
tarafından
if you have a aftermarket anti theft device installed under the steering column they wont let the main relay go to sleep mode, so it keeps a constant draw above 1 amp. sleep mode draws about 0.025 amps. when you turn engine off, sleep mode occurs about 15 mins later
tarafından
I just bought a 2003 mustang… battery was dead bought brand new one and drove home…whome...went out to start car this morning battery was again dead…also car feeks like it's losing power pulling a hill
tarafından
Where is the hood light located?? My father is having this same issue with his 2000 Ford Mustang.. the hood light is the last possible thing he has to check.. he just needs to know the location.. (there isn't a light anywhere.. that's visible..) Thank you.. any help is appreciated
tarafından
I have a 1999 mustang the v6 3.8 and it’s doing the exact same thing however my speed odometer , my fuel gage and my mileage don’t work either and I can’t figure it out. And then the other day I was talking to a guy who worked on fords all his life and he said it’s a common issue with the mustangs around that year and he told me that it was the ecm under the stereo he said that he had the exact same problem in his moms fox body mustang, he said he got a new ecm and it fixed the problem completely so I’m gonna try it and see what happens.
tarafından
3 tane daha yorum göster
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
I had the same issue with a 2001 Mustang. Here is what I found out in the hopes it will help some one out:
Battery would be dead after a few days if car was not driven. Checked current from battery with car completely turned off. Over 300mA current. Started pulling fuses under the hood. 40A Maxi fuse number 6 caused the current draw to drop to a few milliamps. Problem was shorted output transistors in the Mach sound system bass amp in the trunk (right side). Found it by pulling connectors, one at a time. Seems the amps get standby power to keep the electronics “warm” to avoid a pop when turned on. Found replacement transistors at Digi-Key electronics and fixed it up. All works fine now and car can sit for two weeks and start just fine.
Now for the data that will help you troubleshoot:
When operating normally, remove fuse F6. Put your meter in place of that fuse and set on Milliamps DC. When you close the doors with the car off the meter will read over 200mA (I have an LED dome lamp - yours may vary) until the dome light shuts off. Then the meter will read about 112mA for about 40 minutes. After that the PCM goes into standby and the meter will read about 12mA steady state.
Anything else, and you have something causing a parasitic draw on the battery.
BTW, I mentioned this repair to my daughter who used to drive the car and she said “Oh, yeah. That was Bone Thugs and Harmony”
Bu yanıt yardımcı oldu mu?
Puan 5
10 Yorum:
Hi @the_tinker I have 2004 Mustang GT and I am seeming to have the same problem. The car runs fine and I have replaced the battery once but after letting it sit for about one day it will not start at all. I have run a parasitic draw test and when I pulled fuse 6 40a maxi in the fuse box under the hood it took the draw from over 300millamps to 30mA. I was wondering if you could tell me a little more about how you fixed the problem in your car.
tarafından
Do you have the Mach sound system? If you do, crawl into the trunk or pull the rear seats down and unplug the connectors from each amp in turn. The amps are mounted on the underside of the package tray. If the parasitic draw goes away, then you found the bad amp. It was obvious which power transistor was blown when I opened it up.
tarafından
Good evening John and others, We have a 1999 GT with the same problem and it does have the Mach 460 Amp system. To cold for me to remove Amp wires. Quick question if that #6 Max fuse is removed, will the draw stop? Temporarily until I address the Amp issue. Thank you. Ray, Fishkill, NY
tarafından
Ray,
It will but you lose most of the center dash power too.
tarafından
Ty, when it warms up my son (19) away at college will have to crawl back there. We thought that it was the GEM Module because when that fuse was disconnected the draw stopped. Does the Amp feed/back through the GEM? Ty again Ray
tarafından
5 tane daha yorum göster
Yorum Ekle
That seems to be a common problem with those Ford's.
You could install a kill switch until you can pinpoint the problem.
I will look around on the Stang forums for an answer.
Puan 0
2 Yorum:
Thank you I have look at some stang forums, but no luck on my end
tarafından
So i just baught a mustang where they recently dropped a 1999 SVT Cobra engine in and when I bought the car we went to start it the battery was dead which gave it a jump the car started stayed on for a while then the battery light came on and battery voltage went lower and lower till it died and then I bought an alternator same thing is stayed on Jennifer for a while until it died I went back try another alternator did the same thing the alternator I got was off of Grand Marquis it said they were compatible so I've been just swapping out batteries sometimes it charges sometimes it doesn't
tarafından
Yorum Ekle
Ok try this: Check battery voltage while car is running. It will probably be around 12v or 12.5, it is not charging at this rate.
Connect a grounding wire (#4 copper) to the bracket of the alternator and to the negative post of the battery and check voltage again, now you should read 14v or better and the battery is now charging correctly. If this works make the connections permanent and secure the wire in several spots.
Puan 0
5 Yorum:
I understand what you are saying and the battery is charging correctly. The drain in the battery is when the vehicle is not in use. What is confusing is when I pull the #6 high currency fuse the draw stops, but the odd part is when I use a test light to both the terminals on the #6 fuse block, it shows no current at all. When I put the fuse back in, the current again flows thru the fuse. This is confusing. Thanks for you answer though.
tarafından
Can you read the amount of voltage?
Sometimes it can be a glovebox or trunk/hood light not turning off but I
assume you checked those things.
You're problem is with a light that can be on without the key being in the on position or the engine started. Trunk, hood, glovebox, dome light or a dead short in one of those circuits.
tarafından
When you put the fuse back in, there is a current drain, when you test with your test light, the bulb does not light up as the drain is so small that the bulb will not show any illumination. Use your AMP meter and test the amount of current drain then let us know, you will need a good wire diagram to trace the problem, we can help if anybody has a diagram to share.
tarafından
OK I will try both what Michael posted and you Duane. I have the actual Mustang Mach I manual that should show a wiring diagram. I will let both of you know.
tarafından
I have completely taken out the mach sound system out of my car and it still kills the battery after 4 or 5 days ?
tarafından
Yorum Ekle
The most common cause with Ford’s battery draining is the voltage regulator located in the alternator. It is not a difficult job to replace once you have the alternator out of the car, and the voltage regulator sells for about $15 on ebay.
If not mechanically inclined have the alternator replaced.
Puan 0
Yorum Ekle
Put a cd in player and leave it in and that will fix Cd payer is looking for cd all the time even when switch is off I found this on my own It works i know and now you can donate a dollar to me Lol
Puan 0
Yorum Ekle
Update : I found that my amp for the speackers got wet ,I have a convertible, and shorted out hence it was draining the battery. Replaced the amp and have'nt had any problems since.
Puan 0
Yorum Ekle
Yanıtını ekle
Stony sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 27
Son 7 gün: 168
Son 30 gün: 568
Her zaman: 34,500
