Ana içeriğe geç
The Ford Super Duty (also called the F-Series Super Duty) is a series of trucks produced by Ford Motor Company, an American automaker.
locate park light relay f-250
2003f 250 where is park light relay located?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @shosteen
The owner manual for your model vehicle doesn’t show a relay for the parking lights but it has got a fuse for the exterior lamps.
Check if fuse #17 in the passenger compartment fuse panel is OK.
Here’s an image taken from the manual that shows the location of the fuse
(click on image to enlarge for better viewing)
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Light switches are always burning if you dont find the problem elsewhere, open up the light switch and inspect for black spots.
tarafından
Check wires at door jam inside rubber boot cracked shorting out
tarafından
Relay is behind radio along with trnsignal flasher
tarafından
Yorum Ekle
Yanıtını ekle
Stephen Shooner sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 49
Her zaman: 2,672
