Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Soru Tümünü görüntüle
Soru Kapandı
Why my iPhone 4 cannot restore 1618. Stuck in DFU mode?
OK i have an iPhone 4 here. It doesn't boot up, see absolutely nothing on the screen, I have tried Tinyumbrella and it says its in DFU mode, iTunes is saying its in recovery mode and needs to be restored, I've used iReb and it says it is in a Pwned state but whenever i try to restore in iTunes with custom or stock it gets to either the apple or snowbreeze logo on screen and the spinning wheel and says preparing iphone for restore but then just stops with the 1618 error. I've tried reinstalling and basically anything else I can think of, just cant get passed that part of the restore.
Any ideas anyone?
Update
Thank you so much for ur time taken to help me out here. this is just a new phone. the baseband is 04.10.01 since there is no unlock i was trying to restore a custom firmware to try and unlock it and i did not save blobs and when i did the phone went to dfu mode and always there. till this stage. is a brand new phone. i was using pc and it was giving error 3194 now i am using mac bcos i am able to run tss server on tiny umbrella. in windows tss server does not run is grewed out.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Has this phone suffered any damage? Have you changed the battery or repaired anything on this phone?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Error 1618 is most commonly due to faulty iTunes. I would re-install iTunes. See if fixed. Maybe try another computer to Restore. If that works then at least the iPhone is not the problem.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Download firmware 4.3.2 or4.3.3 open itune, connect iphone, let itune recognize iphone. hold shift +restore look for the firmware you downloaded and click on it, open+restore.
if not success, try again. hold+shift choose same firmware do same.
Note: pay attention on the iphone serial # to appear, once appear you good to go!
You may still have error 3194 or 1015 which is good.
next step is download redsnow: run program+browse firmware 4.3.2+open, let redsnow recognize it, if good, hit next or install cydia, follow redsnow instruction. you should be good to go.
If 4.3.2 not recognize then try 4.3.3
Puan 0
Yorum Ekle
anti virus or fire wall issue
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 6,590
