Ana içeriğe geç
Apple'ın 13 inç MacBook Pro Retina Ekranlı modelinin Mart 2015 güncellemesi olan A1502 modeli, beşinci nesil Intel Core i5 ve i7 işlemciler içerir ve Force Touch dokunmatik yüzeyi tanıtır.
Service Battery message still given after ifixit replacement
The “Service Battery” message is still be given in the battery drop-down menu after I replaced the battery with the iFixit kit. It seems like it was a successful installation other than that.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
Yorum Ekle
3 Cevap
Filtre ölçütü:
RESET SMC
MacBook SMC Sıfırlama Kılavuzu
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
Resetting the SMC is a temporary fix if the battery is faulty but good idea to try at least.
OP check the battery health with an application called coconut battery which can be downloaded online.
After SMC you may see the service battery message dissapear but reappear again if you drain the battery and charge it again indicating the system has found something wrong with the battery.
tarafından
I also replaced the battery with the iFixit kit. The SMC reset didn’t help, I still get the message: “Service Recommended”. Is it a fault with the battery delivered with the ifixit kit?
tarafından
Contact the iFixit store for a replacement.
tarafından
Yorum Ekle
This isn't a problem with the new battery, once the chip detects that the original battery has degraded past 80% (or so) or has started to rapidly degrade and inflate, the message will trigger and it's impossible to remove without paying for an official battery change from apple. This is obviously a way for apple to limit what people can fix and sell on (nobody will buy a phone with a "severely degraded battery message" even if the battery is effectively brand new and and 100%).
Puan 0
5 Yorum:
That is not true! you need to reset SMC fully to clear the set value. Or the battery is defective.
tarafından
So how do you do that ?
tarafından
@esnew -Did you follow the steps in the guide rustedchip pointed to just above?
tarafından
Im not sure where that is. Looking for rustedchip
tarafından
@esnew - Here’s the same URL link MacBook SMC Sıfırlama Kılavuzu
tarafından
Yorum Ekle
Had a similar issue recently, tried two new batteries but service recommended message still present. Coconut Battery confirmed both new batteries were healthy. SMC Reset did not help but on a whim I tried an NVRAM Reset and bingo, message went away!
Puan 0
Yorum Ekle
Yanıtını ekle
Gregory Brunkalla sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 3,148
