Ana içeriğe geç
Motorola Moto Z4, Motorola'nın Moto koleksiyonuna aittir ve XT1980-3 ile XT1980-4 model numaralarına sahiptir. Ayrıca 5G desteği de mevcuttur.
Screen replacement tools ands part
Cracked screen I need parts
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
6 Yorum
InjuredGadgets.com
tarafından Paylaş
So where is the guide to fix it?
tarafından Paylaş
Could not find any guides there.
tarafından Paylaş
@ruppertj It opens up just like the Z3, but the ribbon is on the right side. I would recommend disconnecting the battery first.
tarafından Paylaş
Well this was a day late and a dollar short, It would have been helpful if the cause of the screen separating from the body was caused by the battery expanding from gas build up. This did not effect the battery performance but it surly is the cause of the screen separation. This should be noted as the main cause of screen separation and the screen cannot be replaced until the battery is replaced. I wasted two screen replacement kits Z2-Force and Z4 because of the batteries had expanded. This was the cause in my Z2 and Z4 screens to separate.
tarafından Paylaş
1 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
There are suppliers online.
Just search for Moto Z4 LCD part with tools to get results.
Here are just two suppliers found on a quick search
example 1
example 2
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
InjuredGadgets has the screen as well but I would get the Genuine and not the other cheaper one from them.
tarafından Paylaş
Yorum Ekle
I think iFixit sells a wide range of tools and replacement parts, if that’s what you mean.
Puan 1
1 Yorum:
If you read carefully no that not what I mean ...moto z4 is the title
Screen Replacements tools and parts ..that the subject...and finally
Cracked screen ,,I need part that's the message..
tarafından Paylaş
Yorum Ekle
Both of those examples are LCD screens which are for the cheaper Moto z4 play. The original Moto z4 has an OLED screen. Make sure to look out for this because as far as I've researched, they are not compatible with each other.
Puan 1
Yorum Ekle
Yanıtını ekle
Alexandre Domon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 34
Her zaman: 3,704
