Ana içeriğe geç
2002-2007 (KJ) model Jeep Liberty, kompakt 4 kapılı bir SUV. Hem 2 tekerlekten çekişli (2WD) hem de 4 tekerlekten çekişli (4WD) seçenekleriyle satılmıştır.
cluster gauge shift indicator light not working
2006 jeep liberty my cluster gauge shift indicator light not working, check my fuses there good anyone no what could
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum
The light in the instrument cluster or the one on the shifter itself?
tarafından
The shifter light
tarafından
The PRNDL light by the shifter?
tarafından
Yes the PRNDL indicator light
tarafından
The light indicator in the cluster
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Have you checked that the lamp itself in the shift assembly is OK, you didn’t say?
Here’s an image taken from the 2006 Jeep Liberty repair manual wiring section
It shows that power for the shift assembly lamp is the same power that supplies the instrument cluster panel lamps.
If the instrument panel lights are working then you need to check if there is power coming from terminal 21 of the junction terminal block ( see p.8W12-2 & 8W12-3 in the manual, orange / brown wire) or if it is getting to terminal 1 of the shift lever assembly block.
If the power is OK at the shift lever assembly block and the lamp is OK check that there is an earth at terminal 2 of the shift lever assembly block.
Resim
(click on image to enlarge for better viewing)
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Is this under the hood diagram?
tarafından
Hi,
It is a diagram of how the wires run from the fuse block, wherever that is, to the shift selector and other parts of the transmission control system so parts may be under the hood, and others are inside the cabin.
I don't know about your car but I know how to read a circuit ;-)
Check if you get power for the lamp on terminal 1 of the wiring connector at the shift lever assembly when the shift indicator light in the instrument panel is on, as it is the same power feed and you said that this lamp works OK.
If there is no power there then go back to the fuse panel and check if it is leaving there on the terminal indicated in the diagram above. If it is there then there is a break in the wiring to the lamp. Check the harness connections for the wire. may be easier at the shift selector first.
If you do get power at the shift lever wiring connector then check for an earth at pin 2 and / or check that the lamp is OK
tarafından
Ok I will in a bit thank u
tarafından
Yorum Ekle
Yanıtını ekle
Rene Silva sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 2,110
